Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby American, Inc.
Like Tree1Likes
  • 1 Post By 1795
Old 01-10-2020, 07:48 PM
Default CSX Front End Ride Height ?
I have noticed more than one CSX with an unusually large gap between the top of the tire and the fender gap when viewed from the side. It just doesn't look right. I figured these had adjustable coil overs so the ride height could be adjusted.
Can anyone explain why some of them are this way?
(Please don't think I am knocking these cars. They are beautiful. Just trying to understand.)
Tom
Old 01-10-2020, 08:07 PM
Cobra Make, Engine: CSX4000, 427
Well, if I remember correctly, the "correct" ride height I think is 4" from the bottom of the frame for the front, and 4 1/2 " for the rear. They do have adjustable coil over shocks. I know my cars have scrapes on the front body area below the oil cooler ..
I would think the size of the tire can also contribute to the gap, obviously if the tire is undersized.
as far as why have some larger gaps, I'd guess you'd need to talk to the owners, or who ever set up the suspension.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 06-15-2020, 09:00 PM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
agreed, most people set the ride height very high... I am curious as well
Old 06-16-2020, 04:23 AM
t walgamuth's Avatar
Just as a comment the original cars had a lot of ground clearance. I would estimate at least 6" judging from the old racing pictures.
Old 06-16-2020, 04:58 AM
1795's Avatar
The discrepancy in front end clearance from top of tire to fender may also be due to how the car is driven. A car that is raced or tracked hard will need more clearance between the top of the tire and the fender as there is a lot of compression in hard corners under speed. A car that is driven just on the road does not need that much clearance as it will not experience the same amount of body roll and compression when cornering.
ERA 626 likes this.
Old 06-16-2020, 02:10 PM
1985 CCX's Avatar
ERA has the measurements in the website I think.
From CSX3252 or something like that.
Remember race cars were lowered. So all bets are off for that!
