Carroll Shelby - Shelby 427 FE Engine Parts and Services
s
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby Enterprises Inc.
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
Old 06-10-2004, 04:40 AM
Roxie_427's Avatar
Cobra Make, Engine: Shell Valley, Shelby Aluminum 427, stroked
Send a message via AIM to Roxie_427
Default External Slave Cylinder
Chris,
The Shelby external slave cylinder was mentioned in this thread: http://www.clubcobra.com/t52898.html
What brand/type is it and where is it mounted? I couldn't find mention of this cylinder on the carrollshelbyent website.
Thanks!
Tim
Old 06-10-2004, 11:08 AM
Tim,
The cylinder winds up being about 1/2" directly above the driver's side frame rail. It is a push-style setup, so the cylinder is on the engine side of the bellhousing. The actual cylinder is a Girling. All the bracketry is laser cut to Shelby's print. Included are:
- Slave Cylinder
- Block bracket
- Pushrod
- Return Spring
- Reinforcement bracket for use with stock bellhousing only.
Thanks for asking; I hope this helps!
Chris Weisberg
Carroll Shelby Enterprises
(310) 538-2914
Old 06-10-2004, 12:38 PM
Brent Mills's Avatar
Administrator
To confirm, anyone with a Kirkham using this setup?
Someone mentioned having to do some modifications to the fork, but this kit which has been discussed as working correctly for CSX cars doesn't mention mention any fork changes that would be needed. Are there any clearance issues I should be concerned with on a Kirkham?
Old 06-10-2004, 05:00 PM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
Brent,
The fork would need to be modified. The fork I have always used has triangle shaped "ears" out in the pushrod pocket. If you were to grind off the ear and contour the end to match the pocket, it will work fine.
kris kincaid
Old 06-10-2004, 05:22 PM
Administrator
Thanks Kris. Any chance you have a picture? That would be really helpful.
Old 06-10-2004, 05:30 PM
computerworks's Avatar
Kris ... is this what you are speaking about?
Old 06-10-2004, 05:31 PM
Specialk's Avatar
Dang Ron, I was just getting ready to post the SAME PICTURE!! Talk about quick draw!
kris kincaid
Old 06-10-2004, 05:33 PM
(....as I coolly blow the wisp of smoke from my mouse)
Old 06-10-2004, 05:43 PM
Administrator
Oh, well, that should be easy enough. Thanks fellas!
Old 06-10-2004, 06:34 PM
Roxie_427's Avatar
Thanks for sharing, everyone.
Chris, when I get closer to that point, I'll give you a call.
Tim
Old 06-11-2004, 10:00 AM
You guys wouldn't happen to have a picture of the fork installed showing why it needs to be modified a such? Just curious.
Welcome, from Carroll Shelby
Have you noticed that it's tough finding quality performance parts to build a reliable FE engine? I have and I decided to do something about it by introducing my own line of Shelby FE™ performance parts. I worked with my design staff to build the best, because my name is on them. My racing legacy with FE performance engines extends back to my race winning 427 Cobras and GT-40 Mk.IV racers that won LeMans. Three decades later, my newer Shelby FE™ parts utilize proven design refinement to create FE performance parts for the new millennium.
My catalog illustrates an overall selection of parts available, but we can supply complete engines or parts from oil pan to carburetor to build your own Shelby 427 FE™ aluminum or cast iron engine just the way you want it. Call and speak directly to our engine department with your tech questions and orders. You have my name on it.
~ Carroll Shelby
Engine Home  |  About the Shelby 427 FE  |  Engine Parts  |  Contact  |  Tires Home
CARROLL SHELBY ENTERPRISES, INC.
19021 S. Figueroa St.
Gardena, CA 90248-4510
Tel : 310-538-2914
Fax : 310-538-1815
