Carroll Shelby - Shelby 427 FE Engine Parts and Services
s
Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shelby Enterprises Inc.
User Name
Password
Club Cobra Home Register FAQ Members List Calendar Today's Posts
Old 09-10-2004, 08:50 PM
Default Shelby 427 weight?
What is the weight for a complete aluminum Shelby 427? Thanks
Old 09-13-2004, 08:37 AM
Unfortunately, I don't know the weight of a fully dressed Shelby FE. So far, in the time I've been here, we haven't weighed one before it shipped.
I believe the block weighs ~125 lbs; ~130 lbs including steel main caps and fasteners.
Hope this helps,
Chris Weisberg
Carroll Shelby Enterprises
(310) 538-2914
Old 03-29-2006, 05:51 PM
Roughly 465-485 #s. Depending on the internals and ancillarys.
Old 04-04-2006, 04:01 PM
silverstreak's Avatar
Cobra Make, Engine: CSX4812, 511" SHELBY #578, TWM throttles, electromotive EFI/DIS
I had imagined that I would probably not be in the right place at the right time to weigh my beast all by itself when assembled, so I,ve been weighing all my components as received. It goes like this:
Shelby block with main studs, main caps, cross bolts and head studs 122#s
Scat stroker crank 57#s
Scat steel rods, JE pistons, pins,rings 12#s
bhj balancer 7#s
Mc Leod flywheel 28#s
2 KKR stage 2 heads fully assembled 53#s
2 Erson shaft mount roller rockers 12#s
Crane hyd rllr lifters ?#s (still on backorder)
Smith bros pushers 2 #s
TWM FI manifold, throttles, injectors, and linkage 39#s
Armondo pan, tray, pickup 15#s
Shelby water pump 10#s
Powermaster starter 10#s
Total so far 367#s
I don't think roller lifters and a set of fabbed alum valve covers are going to rack up the additional 100#s that Maverick is calling for. I guess we'll see pretty soon.
Old 04-07-2006, 06:19 AM
"I don't think roller lifters and a set of fabbed alum valve covers are going to rack up the additional 100#s that Maverick is calling for. I guess we'll see pretty soon."
Plug wires
Old 04-07-2006, 09:29 AM
The weight quoted is carb to pan.
Welcome, from Carroll Shelby
Have you noticed that it's tough finding quality performance parts to build a reliable FE engine? I have and I decided to do something about it by introducing my own line of Shelby FE™ performance parts. I worked with my design staff to build the best, because my name is on them. My racing legacy with FE performance engines extends back to my race winning 427 Cobras and GT-40 Mk.IV racers that won LeMans. Three decades later, my newer Shelby FE™ parts utilize proven design refinement to create FE performance parts for the new millennium.
My catalog illustrates an overall selection of parts available, but we can supply complete engines or parts from oil pan to carburetor to build your own Shelby 427 FE™ aluminum or cast iron engine just the way you want it. Call and speak directly to our engine department with your tech questions and orders. You have my name on it.
~ Carroll Shelby
Engine Home  |  About the Shelby 427 FE  |  Engine Parts  |  Contact  |  Tires Home
CARROLL SHELBY ENTERPRISES, INC.
19021 S. Figueroa St.
Gardena, CA 90248-4510
Tel : 310-538-2914
Fax : 310-538-1815
