Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 07-04-2003, 03:46 PM
Default Engine mounting question
Hey guys...
OK...there are two engine mounts: the one that bolts to the block...and the other ones that connect the engine mounts on the block to the frame.
Now that we got that scenario straightened out, I noticed that there are three holes in the frame, and only two in the brackets that connect the block mounts to the frame. Which pair do you use on a small block Ford?
Old 07-05-2003, 06:55 AM
Wink MOTOR MOUNTS
Hi Brent
Talked to you when I was with Team C Racing when you needed headers for your motor. I am now with Shell Valley they now have a second location in Conn. The motor mount is a new style to accept all the differt motor companations I beleave you would use the back two holes for a small block , the two forward holes are for the big blocks.Bret give me a call Monday and I will know.Call toll free 1-877-221-1970 or e-mail www.shellvalley@snet.net
