05-04-2005, 02:17 PM
AL
Cobra Make, Engine: Shell Valley, 302, a work in progress
Quick Release Steering Wheel on a Shell Valley Setup
Hi Guys!
I have another question! I have a Shell Valley Steering setup with a Shell Valley 3 hole deep dish steering wheel. The rubber is gone in my Double U-Joint Steering Shaft Assembly. Since, I cannot find anyone to sell the rubber in the end of the shaft. I am going to have to buy a new one.
Well I am sure all of you know how these projects snowball! I got to thinking, if I was going to replace the Double U-Joint and since I had the whole column out anyway, it would be cool to have a detachable steering wheel!
Also I need a new center cap for my steering wheel, does anyone know of any cool one? The one I had was a chrome cap with a glued on Cobra emblem on it (like the ones on the front and rear of your car).
Does anyone have any guidance that they would like to share, before I buy someone parts that I will never use?
Once again I appreciate everyone's help!
Killer
Killer
05-04-2005, 02:19 PM
AL
BTW, the end of Shell Valley steering column just slips on and is held by 3 bolts. It is not threaded like some other ones.
Thanks again,
Killer
Killer
05-04-2005, 03:17 PM
Cobra Make, Engine: shellvalley 428 ford
KILLER, I AM USING THE STAINLESS HOT ROD COLUMN WITH QUICK RELEASE FROM SPEEDWAY MOTORS. TURN SIGNALS ON A TOGGLE SWITCH. GOOD LUCK,
BYRON W.
05-04-2005, 05:26 PM
killer are you talking about the rubber down by the steering rack?? That is called a rag joint. I would call Shell Valley and see if they have one or can tell you what make and year you need if you don't want to replace your steering column.
05-05-2005, 05:06 AM
AL
Thanks Byron, I will look at Speedway columns.
Thanks SVMCobra, that is the rubber that I am looking for! Since I do not know what make and model, I will give them a call this morning (hopefully they will tell me).
I appreciate the help!
Killer
Killer
05-05-2005, 06:18 AM
KILLER, I AM ALSO USING THE U-JOINTS, SHAFT AND A VIBRATIOIN-U-JOINT COMBO FROM BORGESON. REALLY GOOD PRODUCTS AND REAL EXPENSIVE. GOOD LUCK!
BYRON W.
05-05-2005, 06:20 AM
KILLER, MY BRAIN OVER RAN MY HANDS. THE BORGESON PRODUCTS ARE NOT REAL EXPENSIVE AND GREAT QUALITY.
BYRON W.
05-05-2005, 07:11 AM
NE
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
The rag joint is just a standard Ford rag joint. We don't stock them but you should be able to find them at a local parts store. I've found them before in the "HELP!" section where they have door handles, window cranks, and other bits and pieces.
As for the quick release, we use a standard GM 3-bolt hub so the racing quick release units such as what speedway ( www.speedwaymotors.com) work great.
Dana
