Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Shell Valley Companies
Old 02-24-2007, 02:48 PM
Cobra Make, Engine: Shell Valley, 302, a work in progress
Default Aluminum Radiator for a Shell Valley Cobra?
My Shell Valley Radiator got a hole in the main side support today from rubbing against the body. So now I need to buy a new Radiator for it. I would like to get the best radiator I can for it, so I was wondering what everone would recomend? BTW, it has a manual 5 speed transmission with a Ford Crate 302 and a 16 pusher fan mounted on the front of the radiator.
Thanks,
KillerBox
Killer
Old 02-24-2007, 02:51 PM
1985 CCX's Avatar
Try:
Absolute Radiator see Cobra fitting. You can see the Cobra Fluidyne in my gallery.
Best of luck,
Jeff
Old 02-24-2007, 04:57 PM
Jeff that looks like an excellent radiator but, the inlet and outlet on the wrong sides compared to my old one. My top radiator hose is on the passenger (right) side. My bottom hose is on the drivers (left) side. I wonder if you can special order one like the one I already have in the Shell Valley?
Thanks,
KillerBox
Killer
Old 02-24-2007, 05:08 PM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
If my memory is correct{who knows at my age] chevys are top left bottom right and fords are top right bottom left[drivers side]
Old 02-24-2007, 06:36 PM
1985 CCX's Avatar
FYI,
Cobras used a Chevy top left type port inlet. I am about the install this Fluidyne in my CCX which has the Ford set up now. It is only hoses that need to be re-worked. Easily accomplished.
Jeff
Old 02-26-2007, 03:21 PM
hog hog is offline
Cobra Make, Engine: Shell Valley 351W Tremec 2004 Cobra SVT Convertible
Shell Valley should have a radiator. They are excellent to work with.
hog
