Old 11-02-2009, 07:55 PM
Cobra Make, Engine: AddVintage, 351C
Default Leaking oil cooler
I am down to my last few leaks. I got fed up with the crappy (scew on in place of the oil filter) housing leaking. I just put a shorty spin on filter in place of it and found a washer and nut on the discharge pipe coming out of the block (351c). I haven't banged on Fords much and am still learning. What in the heck is that nut and washer for? I removed it prior to spinning on the filter but now, thought I'd better ask before starting the engine... Thx.
Old 11-03-2009, 11:51 AM
MaSnaka's Avatar
It might help to know what size the nut and washer are. I found a little 1/4" nut rattling around in my drivers side muffler. I have no idea what it's from. Good luck with yours.
Old 11-03-2009, 12:16 PM
most ford engines have a jam nut on the oil filter stud but i dont ever remember seeing a washer under it.
Old 11-03-2009, 01:07 PM
Rick Parker's Avatar
http://cgi.ebay.com/ebaymotors/NOS-F...mZ310178931421
Like This?
Old 11-03-2009, 06:53 PM
Default No, not like that but close.
Not sure what I have run across now. The nut was the same size as the pipe and the washer under it. Since the nut was loose I suspect it was causing my cooler adaptor to not seat all the way..... I went to two speed shops and talked to three Ford Pros and they had never seen such a set up. I have since removed the nut and washer and installed a short filter. Seems to be just fine..... Thanks everyone....
