Old 01-03-2010, 12:02 AM
Ant Ant is offline
Default CV Joint operating angle
I have a set of chrome moly 6 ball & cage inner/outer joints and 300m axles etc built to handle over 600bhp at the wheels!! I have just checked the angle of the axles and they are around 6 degrees uppermost at the wheel,
I was sort of hoping the angle was less, anyone have any tips on cv joint angulation, the inner cv joint will hit the top suspension arm if I raise the diff so I am stuck with this angle!
Maybe the only issue I will have will be a slight hp loss at high speeds?
A J. Newton
The 1960's rocked!
Old 01-03-2010, 12:46 AM
LMH's Avatar
LMH LMH is offline
Hey AJ
I can remember when I was into VW's that some of the off road guys were running 930 CV joints at around 25 degrees. I would think 6 would be OK but someone correct me if I'm wrong.
BTW, is that measured at ride height?
Old 01-03-2010, 03:29 AM
Ant Ant is offline
Default CV Joint operating angle.
Gooday Larry,
Measured at ride height, but I have made a mistake in the length between joint centres, the angle is actually a mere 4 degrees! I have read where some angle is better than none so the joint balls wear over a larger bearing area.
A J. Newton
The 1960's rocked!
Old 01-03-2010, 08:22 AM
LMH's Avatar
LMH LMH is offline
Yeah, I'd say some angle is needed. Otherwise, it won't lube the internals.
4 degrees sounds like it would just fine.
Old 01-03-2010, 02:27 PM
Ant Ant is offline
Default CV angle
Larry, thats a good way of putting it. I have since read on the net where over 5 degrees can cause some vibration etc (at high speed) with some types of cv joint, so we are on the right side hopefully.
A J. Newton
The 1960's rocked!
Old 01-03-2010, 02:45 PM
Check with the Kirkhams, they've changed over from standard U- joints to C-Vs, I'm sure they did all the research for optimum settup
Old 01-03-2010, 06:02 PM
joyridin''s Avatar
I was told a few years ago by a custom driveline manufacturer that you can run up to 26 degrees on a CV joint. Anything past 15 degrees and they get pretty weak, but it can be done. You should run a minimum of 2 degrees for lubrication of the bearings to take place.
Old 01-03-2010, 07:29 PM
Cobra Make, Engine: jbl
set it up so under acceleration the shafts are straight as possible, cruising doesn't matter, some angle is probably better for lube. all imo.
