SUPPORT OUR SPONSOR
December 2025
Old 08-19-2001, 04:55 PM
Default Turkey Pan on 351W
I have seen turkey pans on a lot of Cobras but they all were FE engines. Is there some reason you couldn't put one on a small block? They are pretty expensive but I think they look pretty cool and I am thinking of putting one on my Clevor. Comments?
Jack
Old 08-19-2001, 05:45 PM
Bud Man's Avatar
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Default Turkey Pan
Jack:
Seems like the only issues would be setting up the proper linkage entry, and the hood height on your particular car.
Bud
Old 08-20-2001, 08:11 PM
I am running a turkey pan and Hellings replica air cleaner atop my 351W SVO H.O. crate engine. I am using a 750 Holley vacuum secondary carb. Pretty tight fit getting the carb into the pan, but it does look cool. The hardest part was the prep on the pan, as the one I bought required approximately 8 hours of hand sanding (100 grit through Scotch brite) to get it looking good.
Old 08-20-2001, 09:34 PM
Terry Brown's Avatar
Cobra Make, Engine: Superformance, #930, 351W/427CID 419 RWHP (before the Webers!)
I am also running one with the new Holley 770 Avenger. Using a K&N oval aircleaner and 1/2" spacer--makes it snug. Difficult to do much adjuctment but it can be done.
Get the pan polished-makes it look 1000% better.
Enjoy,
TB
Old 09-25-2001, 07:43 PM
Terry... After polishing, do you need to finish it with anything to protect the finish?
I am just completing a Holly to EFI (Access) conversion, and I am planning to mount the throttle body vertical on the Jr. Vic Spyder (drilled for fuelly). This could make use of the hood vent, with the turkey pan.
Since this will not be a stock fitting, does anyone have suggestions on how to size/measure the clearance between the pan and hood? I am limited on space, as an Edelbrock RPM would not fit. I have heard plastercine (sp?) works.
Also, were can I source different size pans? The Finishline pan will be too tall.
Thx.
Old 09-25-2001, 07:52 PM
Oops! Sorry for the slow response but I just saw the question.
1. I just polish it with Mother's when needed. Stays very shiny.
2. I got my pan from Mark Dove at Snakebite Performance. Let me know if you need his number.
TB
HTML code is On
