SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-19-2010, 08:43 AM
elgecko's Avatar
Cobra Make, Engine: Scratch build......a little every day.
Question need help with weatherstripping
I'm seeing if there is a product available to create your own rubberized
weatherstripping for trunks and hood.
Something like a silicon gel that could be applied to the body, lay the Cobra hood or trunk on top and form a "custom" fit . But still be removable once it "sets" up. Maybe by using a release material.
The variations on the underside of my body parts prevents a good seal with traditional methods.
Of course .......Maybe I'm just dreaming.
Thanks
Dave
55 mph is unsafe at any speed. Huh?
Old 05-19-2010, 09:55 AM
Dave,
I do not know of anything like that, but I bet it would be very costly. You can try checking out McMaster-Carr for any specialty stripping that you might need.
www.mcmaster.com
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 05-19-2010, 10:21 AM
elgecko's Avatar
Thanks
I really haven't given up on traditional methods....i'll check out McMaster.
It would be nice if there was a caulking gun method.
Old 05-19-2010, 10:32 AM
check with Soft-Seal.......maybe they have something.......
Old 05-19-2010, 10:53 AM
bobcowan's Avatar
Neutral
In past, I'v had old vehicles with sealing problems. Especially Chevy's with vent windows. Seems like that bit of weatherstripping never fits right. Rather than spend big bux and time, I made my own.
Clean the area really well with alcohol. Lay a bead of silicone slightly bigger than you think you need. Get some saran wrap, and spray a coating of silicone spray on it. Lay the sprayed side down on the silicone. Close the window. After it dries, you can trim away any excess with a razer blade.
I'v never tried it on anything as big as a trunk seal. I'd go down to Home Depot and get the large caulk gun tube of bathroom silicone or insulation.
The sides of the trunk can have large gaps that are tough to seal. From the isnide put a layer of black duct tape. From the outside (through the wheel well), use the same silicone sealant and fill the gap. The duct tape acts like a mold, and hlpes you fill some large gaps.
HTML code is On
