Old 09-03-2001, 09:25 AM
Question Rear tire rubbing
I have just finished my Factory Five Cobra, and I am having a problem with the rear drivers side tire rubbing do to torque. Everything is fine until i punch it, and then it just throws the whole right side over, and the tire rubs on my fender. I have added spacers, and even welded a block to keep the frame from going down, it has helped considerably, but I thought maybe others had been having this problem and there was a known fix.
By the way, I am new, this is my first post.
Later guys
Jon
Old 09-03-2001, 09:34 AM
computerworks's Avatar
Lightbulb Body/Frame problem...
Jon...
I'm sure some of the FFR members here will see and answer your post.
Have you posted the same question on
Cobraforum ?
There's quite a gathering of FFR builders on that forum.
Old 09-03-2001, 11:06 AM
Cobra Make, Engine: FFR 1137 EFI 347
Default Been there..
Evidently your all the way up on the springs already? Probably need to go coil-overs like I need to do. I had 60 series T/A's at one time, and they rubbed a bit. I've gone to 50's, added a sway bar and ground a bit off the inner crossmember and don't have any more rubbing.
Old 09-03-2001, 03:17 PM
Thanks for the help, I think I have it figured out.
