Old 05-01-2011, 05:38 AM
Dav's Avatar
Dav Dav is offline
Cobra Make, Engine: Evans Sports Car
Have you changed the coil .
Old 05-01-2011, 06:59 AM
mreid's Avatar
Edelbrock carbs on light vehicles...hmmm. Hard to tune transitions for consistent afr, but this sounds more ignition related. Wish we could hear it. Got a sound file?
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 05-01-2011, 09:37 AM
I changed the plugs (Autolite AP 26) still got the miss. The only things left to change are the ignition module (Duraspark) or the coil. I must admit to having a cheapo coil from local auto parts store but seemed to work fine before this started. Wife has been understanding so far with the purchase of parts but even I am weary of purchasing more stuff without having a good idea of what's wrong. Today I will trace the fuel system from beginning to end and then check the timing again. I will try to attach a photo of the plugs I removed to show burn pattern and get opinions.
Never throw sand on a carburetor fire
Old 05-01-2011, 10:30 AM
Cobra Make, Engine: Contemporary Classic Car Co. replica of 1966 Cobra made in 1988 with big block bowtie (600 hp 454), Bought about 4 months ago
had a car years ago that got a misterious miss in the engine. Had just put plugs in it. Turns out I had cracked the porcelin on one of the plugs gapping it. Like to never found out what was causing it.
Old 05-01-2011, 10:39 AM
I hope the sound attachment goes through. Does anyone know if I can attach a MPEG4.
Old 05-01-2011, 01:29 PM
EUREKA! I found a small bend in intake house of fuel pump. I think it was restricting flow.
Went out and flogged the car, ran great except have a stumble on gear shifts. Hate to bother you guys but is this probably due to timing or carburator? Thanks for all the helpful suggestions. I sure learned all I wanted to know about misses.
Old 05-01-2011, 03:04 PM
Rwillia4's Avatar
Maybe you have too much fuel now!
Old 05-01-2011, 03:30 PM
Edelbrock Carbs are known for a slight hesitation on throttle tip in. It's a momentary lean condition. Try opening up your two idle air screws about a half turn and see if that helps.
Old 05-01-2011, 05:51 PM
Thanks I'll try that.
