Old 08-24-2011, 04:49 PM
jams's Avatar
Cobra Make, Engine: B & B
Default Radiator weeping
I apparently have a very slow leak in the lower part of my radiator. Looks like where the lower end cap meets the core-probably a lap joint that is soldered together. I have the traditional brass/copper radiator.
I was wondering if I could put my DYI plumbing skills to work and fix it. I figure I can clean, flux and re-solder the joint easily.
Can you just use the home center version of solder?
If it gets too involved I can just take it to a radiator shop or splurge and buy a aluminum one.
Seems like a simple fix so don't want to go overboard!
Old 08-24-2011, 05:17 PM
PeteF's Avatar
You might try adding a can of Barsleak to the cooling system first. It can be very effective on small leaks. Assuming it is still available at auto parts stores. Good luck
Old 08-25-2011, 04:59 AM
jams's Avatar
I did use the Barsleak many years ago in an old truck I had. I just don't know how long it lasts?
Could be an option??
Old 08-25-2011, 05:19 AM
Ron61's Avatar
Post
Jams,
You might pressure test it first to be sure that is the only small place that is starting to seep. I did that to one of mine and I could see other damp spots showing up along the tank seal, so I took it to a radiator shop and had them pull the tank and clean it and then put the whole thing back together. I never had another problem with it.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 08-25-2011, 10:32 AM
Cobra Make, Engine: SPF GT40
Unless your soldering skills are really great take it to a radiator shop. As mentioned you can't pressure test it. It's just not that expensive and you have peace of mind that it's a permanent repair.
Old 08-25-2011, 12:38 PM
Any time in the last 30 years that I have tried to do anything on a radiator myself I just create more problems than I fix. I now pull the radiator, drop it off at a shop, and then put it back in the car after it's fixed properly.
Old 08-27-2011, 09:28 AM
jams's Avatar
Well I fixed it so far so good. I did manage to burn myself .... Oh well
Considering it was a small leak and it's location, I feel confident the fix will hold. If not off to the radiator shop.
