SUPPORT OUR SPONSOR
Old 02-10-2012, 04:29 PM
flaflier's Avatar
Cobra Make, Engine: ERA154 427 HR
Default SW Oil Temp Gauge
I have a question that I haven't been able to find a clear answer to:...
I have a SW oil temp gauge, goes into the front of the oil pan, works great, but when I got under the car, the sending tube is routed all kinds of weird..
Question: can I cut the sending tube (I believe it's mechanical) to an appropriate length?
Seems I read somewhere that the sending units are length dependent...but I can't seem to find that at this time..
Thanks,
Jim
Old 02-10-2012, 05:16 PM
Varmit's Avatar
Cobra Make, Engine: Superformance#2352/Aluminum SO/490 c.i. 650 h.p. 605 tq.
If it is a mechanial do not think so!!!
Old 02-10-2012, 05:27 PM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
The mechanical gauges are sealed units, and cannot be cut or altered (except at the factory, I guess). You should be able to remove the sensor end from the oil pan and reroute the line the way you want it to go. The next time you change oil would be a good opportunity, when there is no oil in the pan. Be careful not to kink the line or put too sharp a bend in it. Good luck.
HTML code is On
