SUPPORT OUR SPONSOR
February 2026
Old 11-22-2013, 02:00 AM
Bryan Wilson's Avatar
Cobra Make, Engine: Real: Southern Roadcraft, SRV8, 351W stroker
Default setting up a hydraulic throwout bearing
My clutch has worn out and needs replacing does anyone know how to setup the hydraulic throughout bearing. I used to have the instruction sheet but have lost it. any help would be appreciated
Thanks,
Bryan
COB-66 Young at heart old fart.
Don't drive faster than your guardian angel can fly.
If it doesn't matter what gear your in you have enough torque.
VK3KDN
Old 11-22-2013, 06:22 AM
mickmate's Avatar
Take measurements off both the motor plate and bellhousing and make sure you have about 3-5 mm clearance between HTO and clutch fingers.
mickmate
http://www.actoncustom.com/
Old 11-22-2013, 07:08 AM
Note that you must limit the total throw of the bearing (by restricting the stroke of the master cylinder) so that it doesn't leave the mounting sleeve (and puke all the hydraulic fluid out).
Old 11-22-2013, 09:05 AM
HealeyRick's Avatar
I used this gauge that Speedway sells in setting up mine. Made it very simple:
Rick
My SBF Austin-Healey build:
http://forum.britishv8.org/read.php?13,8264
Old 11-22-2013, 10:54 AM
PANAVIA's Avatar
are you replacing a old TOB or is this all new stuff >?
as mickmate referred to measure everything and make sure you have just a tick of clearance, depending on the master cyl, you might have to index the throw of the bearing as if the master is too large , you can over-travel the HTOB. A symptom of this is having the clutch release really high up on pedal travel.
Old 11-22-2013, 10:55 AM
jwoodard's Avatar
Here's a link to instructions from McLeod's site:http://www.cjponyparts.com/images/art/install_HCC5.pdf
Jim Woodard
Old 11-22-2013, 04:57 PM
Thumbs up Throw out adjustment
Thankyou every one for the replies and the instructions and schematics from Jim
VK3KDN
HTML code is On
