Old 01-06-2002, 03:58 PM
Cobra Make, Engine: Contemporary, 427 EFI; CAV GT40, 427W
Default Help with pinion angle...
I have a Jag IRS. Currently there is a mismatch of the transmission down angle and the pinion up angle (if these were equal the center lines of the transmission and rear end would be parallel). My mismatch is about 1.5 degrees. What is the maximum allowable?
CAV GT40 Dealer
www.2gmotorsports.com
Old 01-06-2002, 04:31 PM
ERA535's Avatar
Can't you rotate the diff up or down?
Old 01-06-2002, 06:00 PM
With the Contemporary the diff mounts to a fixed plate on top with 4 bolts. I could make a tapered shim if necessary. I was just trying to determine if I need to go to the trouble to make a tappered shim (~4" x ~3") with ~0.090" taper. Not real easy.
CAV GT40 Dealer
Old 01-06-2002, 06:53 PM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
How about raising or lowering the tranny a wee bit? You are correct to bring the centerlines to parallel and non intersecting. But I don't feel that a degree and a half is worth the bother..... unless the horizontal offset results in an angle of more than 6 or 7 degrees.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 01-06-2002, 07:23 PM
Send a message via ICQ to COBRAMIKE427
Default pinion angle
IS THERE VIBRATION?
Old 01-06-2002, 07:40 PM
Cobra Make, Engine: Custom built Excalibur 351C
Default Tapered shims
Speedway Motors has tapered shims for this purpose.
available in 2 degree & 4 degree.
Speedway Motors 402-323-3200
Old 01-07-2002, 05:51 AM
Don't worry about 1.5 degrees of non-parallelism. The miniscule variation in in/out speed will be absorbed by tires and normal drivetrain flex.
Bob Putnam
-E.R.A.-
Old 01-07-2002, 07:16 AM
Roscoe's Avatar
Try this site:
http://www.iedls.com/guide.html
Roscoe
Roscoe
Old 01-08-2002, 08:21 PM
dalola's Avatar
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Cool
I confess I know nothing about the Jag IRS rearends, so perhaps they are different, but most solid axles on a street car should have 4-5 degrees of pinion angle. Also, the electronic angle finders are a really slick way to set/measure it. The better ones self-calibrate, and are very accurate.
Dave
Old 01-09-2002, 03:58 AM
Do not confuse setting up a moving (live axle) rear end with a stationary one (independant).
Now read my first post again.
Bob Putnam
-E.R.A.-
Old 01-09-2002, 06:38 AM
Default keep em greezed
over the long haul, a little 1 dgree or so variation will actually keep the short drive shaft preloaded and possibly eliminate any drive shaft vibration from wear/tolerances. most short shafts are not balanced by the shops only phased for the joints, so they tend to be out of balance slightly.
SonnyB
