Old 01-08-2002, 09:10 PM
Default Vacuum Sorce for Weber Set Ups
Does anyone know of vacuum pump setup that can be used to supply a vacuum for a power brakes while using a weber setup? I thought there was a post on this but I can't seem to locate it?
Dan Hardiman
Old 01-08-2002, 09:29 PM
Wink vacuum
I just installed a system 2 wks ago, and so far, it works great... unfortunately my webers dont. What are your jetting specs?
The link is : http://www.ecihotrodbrakes.com/remote_booster.html
Old 01-09-2002, 05:21 AM
cobrajeff's Avatar
Default You don't HAVE to have a pump
You may not have to resort to a pump to get vacuum for your power brakes. When I put Webers on my Pantera, I made up a vacuum "collector" out of an old fuel log. I ran 1/8" steel lines to each port, and one large line to the connector for the power brakes. I never had any trouble with this set-up.
On my Cobra, I have an automatic trans, so I had to have vacuum for it. I plumbed lines from a couple intake ports to a metal cannister (actually an old "Never-Dull" can) hidden under the car. This is working well, too. For the brakes, I'd pull from all 8 ports, and use a cannister of some kind to store and "balance" the vacuum signal. It'll save weight and money over a pump-type system.
regards,
cobrajeff
CobraJeff
ERA P 202
Old 01-09-2002, 08:21 AM
Ken Oikawa's Avatar
Default Vacuum port kit
Hey, Dan
Ingleese sells a vacuum port kit for a Weber system.
Old 01-09-2002, 08:33 AM
Original Shelby Owner
CobraJeff is right on the money. Use the individual ports (8) and it should provide enough vacuum. A lot of the GT-350's used this set up.
Tony T:
What are you using for etubes, jets, etc?
