Old 01-10-2002, 09:53 PM
Default HeliCoil Problem
I have aluminum heads and one helicoil. When I pulled the plugs, the helicoil came out with it. I understand I need to coat it with loctite and screw it back in.
Anyone know what loctite to use.
Thanks.
Old 01-11-2002, 05:30 AM
dalola's Avatar
Cobra Make, Engine: Project "X" underway....twin turbo V6, AWD...
Cobralee,
If done properly, a Helicoil should not come out. Before using Loctite, you may want re-tap the thread, and try a new Helicoil of the known proper size. Remember, Helicoils use a specific , matching drill and tap. I suspect whoever did this initial repair used the wrong drill and/or tap, in which case, you may very well need to resort to unconventional methods. Also, a little anti-seize compound on the plug threads is cheap insurance!
Dave
P.S. In general, I would recommend Loctite 262 or 272, but you may want to confirm your application with Loctite, 800-562-8483.
Old 01-11-2002, 06:56 AM
Roscoe's Avatar
Also you should use anti seize compound on the plugs. This may prevent it from sticking to the helicoil.
Roscoe
Roscoe
Old 01-12-2002, 11:00 PM
Cobra Make, Engine: HI-TECH 289 FIA
Not all spark plug inserts are Heli-coils. Heli-coil is a brand name of a particlular style, a stainless coil with a patented locking arrangement. Other styles are usually little more than a threaded sleeve which, if not done properly, can easily remain on the plug when removed. I can not imagine a true heli-coil coming out without total destruction.
Regardless of the insert or head material, as Roscoe says, use anti-sieze
If there are still good threads in the head you can usually just reinsert the thread-sert kind.
fiaroadster
Old 01-13-2002, 11:19 PM
Default Helicoil
Actually, it wasn't a helicoil, but a threaded sleeve. So, as many of you recommended, I used loctite 271, which is specific for "thread locking". I'll find out tomorrow if it sticks or not.
Thanks for the input.
Old 01-14-2002, 12:16 PM
Cobra Make, Engine: SPF 974
I would use blue loctite on the outside of the helicoil or insert where it contacts the head. Then use anti-seize on the spark plug thread. This should facilitate removal of the plug with the insert remaining intact.
Old 01-14-2002, 09:32 PM
Default Helicoil
Jam-
Thanks for your suggestion. I already used the 271 loctite, so if that doesn't work, I'll go with your idea.
