SUPPORT OUR SPONSOR
Old 01-22-2002, 11:55 AM
Post Clutch, Flywheel, Bellhousing for a 428
Need some help guys...
I have a 428 and plan to hook it up to a Tremec TKO transmission. I need a bellhousing, flywheel and clutch. I've pretty much settled on the Lakewood bellhousing and I would like to run a Centerforce Dual Friction clutch. Trouble is nobody seems to know whether Centerforce makes a DFC for the 428. Can this be done or should I look for a comparable McLeod clutch? Also, should I opt for a OEM steel flywheel or a new billet steel flywheel? Thanks for your help.
Ken
Old 01-22-2002, 07:16 PM
Heeey Mr. Wilson!
I know Southern Automotive carries bellhouses, clutches, and steel and aluminum flywheels. I am not sure if they will sell them too you without buying an engine though. I have a feeling they will, the Parhams are great folks. http://southernautomotiveengines.com/
Dennis
2500 Pounds of steel, rubber, and fire. AAAHHHH!
Old 01-23-2002, 05:53 AM
Thanks Dennis,
I'll give them a call and ask their expert advice.
Ken "George" Wilson
HTML code is On
