Old 02-03-2002, 07:46 PM
Cobra Dude's Avatar
Cobra Make, Engine: CMC, Supercharged Ford 5.0 & all the toys.
Default Welding on Jet Hot coating...
Can it be done? I need to weld tabs onto the exhaust hangers of my sidepipes. Not sure what "ceramic" really means as it applies to Jet Hot coatings (or equiv), but can I weld to it? Or do I need to grind off the coating or something like that?
-Neil.
   www.VEIsystems.com
CMC Cobra, Ford 5.0, EFI, Vortech supercharged, T5Z, 8.8 rear, MII front, 4-wheel discs, A/C, stereo.
Old 02-03-2002, 08:02 PM
Rick Parker's Avatar
You cannot weld on the ceramic surface of the coated parts. The fusion process that occurs during welding requires that the parent materials be of metal, ie: stainless steel, mild steel or another similar type of alloy. You will have to grind away the coating or find another way to attach the tabs.
Rick Parker
Old 02-03-2002, 09:57 PM
Cobra Dude's Avatar
Default Ceramic = ceramic
So by "ceramic", they really mean some variant of what I've grown up to know as ceramic, huh? I can live with that. I guess I can grind off some of the coating and weld. Rather than shipping off the pipes to Jet Hot again, I'll just dab some silver paint on that area -- it's not very visible.
Thanks.
   www.VEIsystems.com
Old 02-04-2002, 02:56 AM
750hp's Avatar
If you were talking Jet Hot specifically, then I couldn't comment. BUT, we have HPC over here and you can weld over their coating. I had some other pipes porcelain coated through another company, and they couldn't be welded.
It does discolour the surrounding area, but you definitely can weld the HPC. I was talking to them two days ago, because I need to weld in some exhaust temp bungs for datalogging purposes.
Here's an old photo of my pipes. Does the finish look the same as HPC USA?
Craig
