Like Tree22Likes
Old 06-02-2021, 09:55 PM
Taking the headers off is probably the best idea and will certainly make wrapping then much easier.
Bruce.huling likes this.
Old 06-03-2021, 10:22 PM
Cobra Make, Engine: Lone star 351w /408cu.in.
Hey Carl
Took off the header. Will get it welded then hit it with ceramic header paint.
Chasing a water leak now on front near intake manifold. Need to get to store and rent pressure tester so I can be sure.
Old 06-04-2021, 03:54 PM
Bruce, if its just a minor coolant leak, I'd dump in a tube of AlumaSeal. I've been using it for literally decades with good results. It won't clog the cooling system, is a water pump lubricant and an anti rust. If it doesn't do the trick, you'll be out $5. It will not stop water pump shaft seal leakage or hose issues but is pretty wonderful on little gasket leaks and radiators. My 2¢ worth.
