SUPPORT OUR SPONSOR
Old 04-08-2002, 06:18 PM
Default Torque Specifications For Jaguar Rear End
I need to know the torque specifications on the inside u-joints of the halfshafts? And also the torque specifications for the nuts that hold the shaft that connects the lower crossmember to the frame.
Many thanx in advance
Craig
Old 04-09-2002, 12:54 PM
Dear Craig,
According to my Haynes Manual for Jaguar XJ6 rear end the torque values for the inner flange nuts on the drive shaft is 55lbs ft and the value for the inner pivot shaft nuts is 50 lbs ft.Hope this is of help for you. If you are doing a lot of work on the Jag,rear end it would pay you to get a Haynes Manual. My particular one bought in the UK is no.242 Regards Jonny
Old 04-10-2002, 08:04 AM
Thanks Jonny,
I'll try and find one. Thanks for the help..
Craig
HTML code is On
