SUPPORT OUR SPONSOR
Old 04-15-2002, 03:12 PM
Send a message via AIM to Rolling Thunder
Default medium rpm 'stumple' problem
Yet another question due to yet another probem. Spring must be here.
Yesterday, the car ran fine. Today, I installed a oil re-route line. To do so, I had to R&R the fuel pump to gain access to the oil gallery plug.
After driving the car for about 20 minutes, it started acting up. At first it would just die while coming to a stop. When turning it over it would take a while to begin firing and restart.
That sympom disappeared and was replaced by a medium rpm, approx. 3,000, stumple or hesitation. If parked, the car would die. If moving slowly, it would cut out and die. Above 45 mph, even at highway speeds, it would still do it, however, after initially cutting out, it would begin intermittantly firing. This would slowly increase until it was running fine again. I believe the engine was actually maintaining revolution because of the forward movement and having the transmission engaged.
I can't tell if it is starved for fuel or if I am loosing spark, or what. When I finally got back home, I lifted the hood and increased the rpm's by pulling back the throttle lever at the carb by hand. I have a see through fuel filter. The entire time as I brought it up to 3,000, the filter was full. After about 20-30 seconds, the car began cutting out and then died. All the while the filter canister was full.
Temp today is approx. 83 with 50% humidity. Car is running approx. 200 degrees coolant temp.
Any ideas on what the problem is? Any suggestions on how to fix it?
Thanks,
Keith
Old 04-15-2002, 05:26 PM
Cobra Make, Engine: Nothing yet- spending money for Cobra on daughter and son's college educations!
Keith-
disconnect the line from the fuel pump and check to see how much fuel it's actually pumping.I had an electric fuel pump
act up on me now and then-I think the pump motor windings were
going bad-it wouldn't do it all the time.If it's a mechanical pump,
and they're designed the way I think they are-could be a cracked
diapraghm(??)Either way-It sounds like the pump isn't putting out sufficient amount of fuel.
-Bob
Old 04-15-2002, 05:43 PM
ERA535's Avatar
Does it die even if you pump the gas pedal?
Old 04-15-2002, 09:57 PM
Default Yes
It dies no matter what I do. I can feather the accelorator, I can floor it, I can give 2-3 part throttle jabs. Regardless, it dies.
Then, it usually needs a couple pumps of the pedal in order to start up again.
HTML code is On
