webers/replica's
Does anyone know where/if you can purchase Weber Carb. replica's?? Lets say, I want the "Weber" look without the "Weber" price. Anyone?? Thanks.
Regards, Shaun |
The closest you will be able to come is to get the fuel injection system....your going to be around $3000-4000 for that....not sure where you can get a set.
Matt |
Wayne Presley imports a nice looking weber type FI, I think from Australia. Wayne is normally on the Cobraforum. As I remember the price was not bad.
Dan |
Hi Shaun TWM Induction makes a look alike weber carb but is for fuel injection from 48 to 55 mm throttle bodys. You can use 1 or 2 injectors, inside or out side mount points. Maybe you can kind some one with a used set. Try FFP in Cali. 562-921-5400 I have gotten good parts from them at good prices. Give them a call. Good luck Rick Lake
here's 2 threads on webers and look alikes:
http://www.clubcobra.com/forums/show...threadid=16969 http://www.ffcobra.com/ubb/ultimateb...=002188#000000 Samurai |
You might want to check Gene Berg's products. They make a Weber look-a-like that is a very good unit with venturi sizes that run up to 58mm.
| All times are GMT -7. The time now is 02:47 AM. |
