Old 05-18-2002, 10:16 PM
Thomas Gayer's Avatar
Cobra Make, Engine: B&B 66 427W Roadster
Default what size bolt?
can anyone tell me the size of the bolt holding on the driveshaft to the front of the differential on an 88 tbird turbocoupe?
it is not 7/16" not 1/2" and looks like a 10 point bolt.
thanks
tomas
SSSSSSSSSSSSS
Old 05-19-2002, 06:57 AM
It's metric. Not sure of the size, but any Ford parts Dept has them. Got a box of 4 of them for a coupla bucks.
Old 05-19-2002, 08:26 AM
jack,
thanks for the reply,
i am needing the yoke on the front of the rear end.
i have an 88 tbird 3.73 posi with disks and need to
pull the yoke off one at a local yard.
i have never seen bolt heads like this before.
on cobra forum they said they are 12mm / 12point
tomas
SSSSSSSSSSSSS
Old 05-19-2002, 08:39 AM
Ron61's Avatar
Default re bolts
Thomas they are 12 meter metric bolts. I have them on mine and had to remove the transmission a week ago. I learned a long time ago to get a set of metric tools as well as standard as it seems everything is about half and half any more.
Ron61
Old 05-19-2002, 09:32 AM
i had a set of metric sockets with me but they were 5 point
(useless)
thanks
tomas
SSSSSSSSSSSSS
Old 05-19-2002, 04:23 PM
Bryan Wilson's Avatar
Talking re bolts
ron61
You realy crack me up 12 meter bolts would be 39.37 feet long or dia. which ever way you look at it.
Bryan
VK3KDN
Old 05-19-2002, 07:02 PM
Cobra Make, Engine: B+B 351w #112
They are 12mm 12 point. I tried to get a impact socket to take them off. Couldn't find one at any local stores. Finally got them off with the third Craftsman socket. First two sockets cracked. Jim
Old 05-19-2002, 08:11 PM
Clois Harlan's Avatar
Default Centimeters, Milimeters, etc
Way to go Bryan, keep us all in line with the correct metric terminology. We will learn this stuff eventually.
I just looked at your pictures-nice ride BUT the steering wheel is on the wrong side Just kidding! Do you take it to any Races down there?
"Let's roll"
"Be part of Something Good
Old 05-21-2002, 07:23 PM
Mr.Fixit's Avatar
I've broken sockets removing these bolts. Often had better luck putting a 12 pt. 12mm box end wrench on them and hitting the wrench with a 3 lb. hammer. Reinstall new bolts with socket. They have that pink thread locking compound on them.
