SUPPORT OUR SPONSOR
Old 06-13-2002, 04:37 PM
ronzara's Avatar
Cobra Make, Engine: Everett-Morrison 351w assembly STILL in progress
Send a message via AIM to ronzara Send a message via Yahoo to ronzara
Default Master Cylinder ?'s
I was wondering what would be the best combination of master cylinder size for my application.
I have Granada Calipers w/11" rotors on th front, and Standard Ford Drums (8" rear end). Manual brakes.
I have a pair of 1" Brembo Master Clyinders, but thought they might be way TOO much for my application.
Would these work???
What do you guys think???
Thanks.
RZ
Ron Zara
ronzara@hotmail.com
1. "Putting a Chevy Motor in a Shelby Cobra is like CUSSING IN CHURCH!"...... ME
2. "Friends Don't Let Friends Drive Junk"....
Old 06-13-2002, 06:40 PM
Mr.Fixit's Avatar
They'll be really hard to push. That is a big bore for dual master cylinder brake setup. The mechanical advantage of having a long skinny master cyl piston pushing a short fat caliper piston lets you translate a long foot travel distance with little force into a short travel brake piston distance with lots of pressure. Then again, depending on the piston size of the caliper and brake pedal arm ratio.......
Old 06-14-2002, 02:19 PM
ronzara's Avatar
I don't know the pistons size in the calipers,... I do know the Wilwood pedal I am using has a 7:1 ratio which may offset the stiffness somewhat... what do you think??
RZ
Ron Zara
ronzara@hotmail.com
HTML code is On
