SUPPORT OUR SPONSOR
Old 11-08-2001, 09:04 AM
PNJSNAK's Avatar
Club Cobra Member
Cobra Make, Engine: A&C 427S/C, 351W, T5
Question Solid Motor Mounts?
Should I be using solid motor mounts? What is everyone else using on their 351W motors or other engines? I have about 325+ H.P. and when I get on it a bit, it really torques to the right. Causing the side pipes to hit the body. I have 1/2" clearance and would like to keep it that way.
I am presently using the Napa 351W mounts with the rubber between the plates.
If others have gone to solid mounts, what would be the disadvatages if any?
Where and what part numbers would I use to fit in the place of the Napa units without having to add or change anything else?
Any help would be appreciated, Thanks.
Jim
HTML code is On
