Old 07-14-2002, 02:56 PM
Default True Air Speed
Have a Contemporary Cobra, 428, toploader, and 3:31 Jag rear. Speedometer seems to indicate 1/2 actual speed. How do you determine the correct size speedometer gear so the speedo is indicating the true air speed? Somebody said there's a website available.
Old 07-15-2002, 09:50 AM
Mr.Fixit's Avatar
A toploader has a 1:1 fourth gear. Your diff as a 3.31:1 gear ratio. Measure tire size (circumference). You should now be able to calculate how fast you are going based on RPM.
Assume 28" tire?: 3000 rpm divide by 3.31 is 906.3 tire RPM
28" tire has a circumference of 7.33'
so, 906.3 multiplied by 7.33' is 75 miles per hour
You would be going 75 mph in fourth gear at 3000 rpm if you have a 28 rear tire.
Old 07-15-2002, 10:46 AM
ERA's speedo gear chart
I suggest you do a timed measured mile and/or compare your odometer to a real measured mile first.
Bob Putnam
-E.R.A.-
