SUPPORT OUR SPONSOR
February 2026
Old 08-10-2002, 07:14 AM
Cobra Make, Engine: Former owner of an A&C
Default Engine Help
I have a 400 Ford .030 over = 406
(Its a 351 C with 1" more deck height)
Stock heads
mild compression bump 9.25:1
Crane Cams 524421
Lift @ .050
220 Intake
230 Exhaust
Cam installed 2 degrees advanced (due to clearance issue with connecting rods) In the first build the clearance was not noticed. It ran strong for about 2 hours, until it sheared the timing keyway. Every other lobe was just sligthly contacing the connecting rods.
All parts inspected and new timing set, cam, lifters, and pushrods installed. Including 1 new valve which had bent. (I don't know which cylinder, but can ask the builder).
Now, I'm bending pushrods on #8 cylinder only. The failure is not during any particular hard running. This is the second time it has happened and I'd like to get to the bottom of this.
Any ideas/suggestion?
Old 08-10-2002, 07:26 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
First thing to check when bending a pushrod is valve spring bind... that is, compressing the spring to the point that it can't compress anymore and passing on the "excess" to the pushrod.
Also poor alignment of the pushrod and rocker arm (guide plates?).
Good luck sorting this out.
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 08-10-2002, 07:32 AM
kountzecobra's Avatar
To bend pushrod, either alignment is off or valve springs are coil-binding. What bothers me most is if you advance cam for clearance, with timing chain wear, you may be back where you started. What cam are you running anyway? Could the base circle be wrong?
Old 08-10-2002, 02:42 PM
427sharpe's Avatar
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
A defective cam is a possibility, but the binding valve spring far more likely. This becomes more likely if the machine shop that did your heads installed too many spacers under the spring to boost tension. When you replace the pushrod this time, replace the valve spring too, and take a hard look at the rocker arm to make sure it's correct and intact. A more remote chance is an incorrect pushrod, but if you've replaced them more than once it becomes more doubtful...
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
Old 08-10-2002, 08:59 PM
Cobra Make, Engine: MIDSTATES, 408C
WADESDAD,
THIS INTERESTS ME AS I TOO HAVE BUILT A 400M BLOCK
CLEVELAND WITH QUENCHED 70 4V HEADS, MOTOSPORT
CAM, RHODES LIFTERS, CRANE ROCKER CONVERSIONS AND
ROLLER LIFTERS. NEVER THOUGHT OR HEARD OF SUCH CAM
LOBE /ROD CLEARANCE PROBLEMS. I BUILT THE ENGINE ABOUT
3 YEARS AGO AND HAVEN'T FIRED IT YET. I LIVE JUST OUTSIDE
CINCI AND WOULD LIKE TO HEAR WHAT YOU FIND OUT AS
TO WHAT WORKS FOR YOU TO CLEARANCE EVERYTHING AND
STILL HAVE IT RUN DECENT.
Old 08-10-2002, 09:14 PM
Cobra Make, Engine: Genuine original Unique MotorCars 427 S/C, with a Genuine original Ford 427 Side-oiler.
Send a message via Yahoo to Cobranut
wadesdad,
I think the correct way to address the clearance issue is to remove material from the rods, or more likely the rod bolts, to correct the interference. Rebalance the rotating assembly afterward.
Your engine builder should've caught this during assembly.
Coil bind, or insufficient piston-valve clearance is most likely the cause for the bent pushrod.
Good luck,
David
Old 08-10-2002, 09:19 PM
Gentlemen,
Do I have "too much" cam? I copied a HotRod Mag build-up as close as practical, but they didn't mention many of the issues I've encountered.
-wadesdad
Old 08-10-2002, 10:39 PM
Back in Black's Avatar
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Wink I am not a cam engineer, but..
The figures you gave seem quite mild, even for it being a SB
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
Old 08-11-2002, 11:19 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Cam is about right for street use. You provided duration, but not lift.
Could be a valve hitting a piston also.
Did your machine shop do any trial assembly on this setup? This should have all been checked, and caught before final assembly.
HTML code is On
