SUPPORT OUR SPONSOR
Old 08-24-2002, 01:28 PM
Question crankcase pulley
I have a 289 in another car and I am trying to remove pulley to install another.
The question is: is it a righty tighty?, if it is: how do I get it off?
the car is in gear, parking break is on, I have two wheels blocked, and it is sliding backward.
I do not want to break anything.
Dana
Dana
Old 08-24-2002, 08:21 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Threads are all the same. Believe these studs are 5/16". Removal should be counter-clockwise, facing the pulley. If they're rusty, use Liquid Wrench (soak for about an hour) then propane torch to heat nuts to remove.
Old 08-25-2002, 05:14 PM
Campy's Avatar
I have discovered in some cases the only answer is an impact wrench. You may need to consider this option. If you don't know someone who has a compressor and impact wrench you may need to rent an electric impact for the day. They will do the job but I have found them not quite as effective as a pneumatic. You don't need the wrench when it comes time to put things back together, you will need to torque this bolt to about 70 to 80 ft/lbs.
Good luck
HTML code is On
