SUPPORT OUR SPONSOR
Old 08-25-2002, 05:20 PM
Default Help I D this Master Cylinder
It just blew out. Thankfully, it was in the garage when it gave out. Unfortunately, I do not believe it is what is in the build manual. It’s a Contemporary made by them in 1991.
The question is what is it and where can I by the rebuild kit for it. The only id is on the band around it. It says ¾, which is the bore size. It is for the front wheels and there is a matching one for the rear. Then I have a third that is for the clutch. It says 1 on the band.
Any info would be great.
Old 08-25-2002, 05:43 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Cobraman,
That looks to be an old old version of a tilden MC.
I bet that a newer Tilden 3/4 will fit right in there. You can get the one that has a remote reservoir too. Man those old brake light pressure switches are antiques. If I were you I would eliminate that feature and put an under dash unit in that works when the brake is depressed it releases the switch.
Hersh
Old 08-25-2002, 06:13 PM
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
The Tilton cyls come in a kit form in a box w/ every resivoir or attachment needed. They run about $60-$68 .They may not be shown in Jeg's or Summit but they have and will deliver.Just ask. 3/4" sound like a brake master cyl.?
Mike H
Old 08-25-2002, 06:41 PM
Tommy's Avatar
CobraMan -
The photo resembles a cast iron CNC brand master cylinder I bought a few months ago. If yours feels heavy like iron rather than light like aluminum, it is probably a CNC product.
Tommy
Previously owned EM Cobra
Old 08-26-2002, 08:01 AM
Mr.Fixit's Avatar
Tommy is right,
It looks to me like the CNC brand, that is if it's steel.
Old 08-26-2002, 07:32 PM
It is steel. Very heavy.
What's the recomendation? Repair? If so, anyone know of a surce for parts? Replace? Probably Wilwood.
HTML code is On
