Old 09-18-2002, 08:46 AM
Cobra Make, Engine: SPF - 427 Stroker
Default Same Spinners For 17" Wheels ????
I am getting ready to put a set of 17" PS Engineering wheels on my SPF (#940). I am being told that I need different spinners for them and cannot use the same ones that are on my 15" wheels that came on the car. Is this true ? Thanks in advance.
NEVER LIFT
Old 09-18-2002, 09:17 AM
Mr.Fixit's Avatar
Depends on which spinners you have. I have lost track of what car # = which wheels on SPF. Place the spinner on the wheel in question, does it fit into the "cone" with good contact? I have done several where they worked fine and I have had some older trigo's that needed to have their spinners turned down to fit into the wheel properly. Phil of PS engineering did this so they would fit the wheels right. If you have the SPF brand of knockoff, I would replace them anyway, they are the weakest ones out there, I have broke several ears of several of those without smacking the crap out of them. Trigo's take a serious licking without breaking.
Old 09-18-2002, 07:39 PM
I just put the 17's on my car and I got the spinners from PS..They are incredible.....
Old 09-18-2002, 08:56 PM
James Baldwin's Avatar
Subsistance du serpent
Send a message via Skype™ to James Baldwin
Halibrand spinners did not work with my 17" wheels. The spinner bottomed out on the threads before it locked the wheel in place.
I use the Trigos for the 17" and they work fine
James
