| S |
| 1 |
5 |
| 8 |
12 |
| 15 |
19 |
| 22 |
26 |
| 29 |
30 |
31 |
09-18-2002, 01:46 PM
Royal Purple synthetic
Anybody out there using Royal Purple in their gearbox? Good or bad??
Thanks
Tim
Advertising
09-18-2002, 04:56 PM
AZ
Cobra Make, Engine: SPF 2180, second one, Roush 427, first one SPF 746, 514 Big Block Strocker
Tim,
I use Royal Purple in my car. It is just as good as any of the high grade oils.
I spent a lot of time in Knoxville, (Oak Ridge), I was there on 9/11.
I am planning to retire in this area.
Somewhere around the Village. I like the area.
09-18-2002, 05:50 PM
CT
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Hey Tim:
I use Redline MTL in my Tremec with good results! In the crankcase it's nothing but Mobil1. What does your transmission manufacturer recommend?
Bob
09-18-2002, 06:22 PM
WA
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
There is an extensive thread on this early this year
And it was pointed out that as far as engine oil, the "racing" version of the royal purple has no detergents, and will gum up your motor...so you need the street version. The racing version is better for anti scuffing but you should not use much, if you do, percentage wise.
Royal purple has some high marks in independant testing..and IF my car ever gets here, after break in, I will be using a mix of high and low viscosity Royal purple.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
09-19-2002, 07:29 AM
Cal
I highly recommend REDLINE lubes. Y&ou can feel the difference if you put redline ATF C+ in your tremec compared to GM synchromesh
09-19-2002, 10:54 AM
WI
Cobra Make, Engine: Shell Valley, Mopar thingy (small block of course)
Hot Rod TV did a segment on it and they got a few more rwhp just by switching, but I have seen dyno results similar to that with Redline. If I can find the site, a C4 vette dynoed at just over 7rwhp switching to Redline. I use Redline products and haven't found any reason to switch yet. Ditto to Mr. Fixit above.
Brent Dolphin
09-19-2002, 11:04 AM
WI
Brent Dolphin
09-19-2002, 05:42 PM
CA
With the Redline ATF C+ in your Tremec, can you grab second quicker? I am running Valvoline 90W and the shifts are very slow. It's hard not to grind second. Will the trans hold up with lightweight ATF in there?
Paul
09-19-2002, 08:19 PM
IL
Cobra Make, Engine: ERA 454 S.O.
Paul:
You are using the wrong lube. All modern manual transmissions use ATF. You probably ruined the syncros, that's why second gear grinds.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
09-20-2002, 09:43 AM
CA
Thanks Jeff, I'll get some before the rally on the 28th. That should make it easier to kick the butt of my friend's Corvette, too.
Paul
HTML code is On
