Old 10-07-2002, 08:59 PM
Cobra Make, Engine: classic roadster, 302, dual carbs
Question ignition switch problem
Hey thx for all the help ahead of time!!!
I'm rewiring my cobra using the e-z wiring kit. the wiring diagram that comes with the kit doesnt match the wire loom in the car. So after using an ohm meter and hooking up the switch i have no power coming from the coil. the car turns over but al the guages go dead while the starter is turning over. the wiring is from a 77 mustang. does anyone have a clue as to the wiring on the ignition?
thx
Old 10-08-2002, 07:31 AM
Mr.Fixit's Avatar
You probubly need to use the bypass ignition lug on the starter solenoid. There are two little lugs on the ford starter solenoid: one is the "on" switch wire, the other is to bypass the ballast resistor so the coil gets full volts during startup.
Old 10-08-2002, 09:55 AM
Check your ign switch leads. Some switch have two output leads. One lead that is 'hot' anytime the sw is on. The other is 'hot' when sw is on & not in the start position. The second lead is an acc. lead (radio). You may have hooked up the coil to this lead. You may need to swap leads.
Larry K Hills
Old 10-09-2002, 07:41 PM
thx for the input.let me try to put this a differant way. the ignition switch has 10 connections. 5 next to 5. as it is sitting in the car the line on the right(passenger side) sarting from closest to the firewall.first and second power all the time 3,4,5 power during running. turn to start and all go off.now on the left. 1,2 on only when running 3rd and 5th only on when starting and 4th only while running. I have 4 wires 1 main power 2 accessorie power 3 to remote starter and 4 to the coil.
I had the car running with the switch not in place.(just used my hand and a hemastat) car ran fine. revved it up (of course!!) and blew the 20 amp fuse i had put in as the fusible link. didnt want anything frying!!!!! so I replaced the fuse with a 40 and thats when I didnt have power to the ignition system anymore.Now I have moved the wires around so much I dont remember how i originally had them. when I turn the ignition switch the fuel pump and all the gauges spring to life. but when I turn the switch to start everything but the starter goes dead????!?!?!!?
ok any hints
thx
p.s. I checked the fusible link connection and its good otherwise the stater wouldnt turn over right? right? ahhhhhh I'm goin nuts
