SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-15-2002, 02:28 PM
Cobra Make, Engine: 65 la exotics 351W supercharged
Default thunderbird supercoupe irs
I am considering switching out my 9 inch rear end wirh an 8.8
supercoupe irs. I am running a supercharged 289, 375 horse,
425 lbs torque. Will the irs handle the torque. How have the 8.8
irs units held up in cobras. Thanks for your input. Jay.
Old 10-15-2002, 02:56 PM
Mr.Fixit's Avatar
They handle it fine. Just don't put on some drag slicks and try and launch the car at 7000rpm. SPF puts them in their cars, and there are a bunch of SPF's with lots more torque and no diff problems. But why switch anyway?
Old 10-15-2002, 03:29 PM
Cobrabill's Avatar
Cobra Make, Engine: Superformance 427 Side-Oiler
I up-graded to an Auburn Pro carrier in my 8.8 and have had no worries.
The rest of the world can have their opinion about the United States just as soon as WE give it to them.
Old 10-15-2002, 03:54 PM
3 reasons for the switch:
#1. I need a winter project.
#2. I auto cross the car & believe the irs will perform better.
#3. I found a complete irs for $500 dollars & should be able
to sell the 9 inch disc. with posi for more.
Old 10-15-2002, 05:53 PM
Mr.Fixit's Avatar
I have never seen an LAE or B&B with IRS. is it supposed to be a drop in assembly? The cost of modifying the frame to accept: A-arms out back, hang the center section, and everything else will be a huge pain, but you said you needed a project. What did you get with the "complete irs for $500"
Old 10-15-2002, 08:53 PM
I like reason number 2. You are starting a poll aren't you? LOL
Ernie
Old 10-15-2002, 10:46 PM
Cobra Make, Engine: kmp927
Default love to see pics of it when your done
i would love to see pics of it when your done as mine is the same as yours and we all need winter projects : )
aeon
Old 10-16-2002, 08:37 AM
I'm checking to make sure the irs hub to hub length is the same as the 9 inch. To shorten or lengthen the irs would be spendy.
The irs I've looked at is a 1992, 327 gears with posi. The unit is
100 percent complete. I actually think the install wil be easy. A wire feed welder & some custom brackets. I will keep you posted. Jay
HTML code is On
