Old 10-19-2002, 11:38 AM
computerworks's Avatar
Default Carb question- Choke?
Question (dumb and simple) for those using a big Holley in a cold-air pan:
How do you handle a choke?
Mechanical? Standard?
...or have you removed the Choke Assembly and don't use it?
Old 10-19-2002, 02:00 PM
custom holley 780 fully enclosed in 'something like' a 'cold air pan', ie, inside a fully enclosed paxton supercharger carb bonnet fighting for air on start up . NO CHOKE in tundra michigan, weather similar to yours. I just play with the throttle with continual gas pedal blips as needed until it warms up enough to idle as it should ( takes a couple of minutes) , as it starts to die i blip it to keep it running. i have talked to several bb folks with big domiinator carbs and many of them do the same having disconnected their choke. bill. .
Old 10-21-2002, 08:16 AM
Mr.Fixit's Avatar
I never run chokes on holleys. You can wire it open with a piece of coathanger, or just remove all the applicable pieces, or go all the way and remove the pieces and mill off the horn. Really cold temps rrequire a touch more skill to keep it running while cold, but it must be freezing for that.
Old 10-21-2002, 08:32 AM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Remove all the choke related parts, they're not needed.
I've never had a problem with the dual 1850's even when it's cold. You just have to feather the throtle for a mile or so and then it's fine. It'll warm up quick enough.
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 10-21-2002, 10:10 AM
wilf leek's Avatar
Ron - I am not running a Holley, I have an edelbrock carb, but I too have stripped off the choke mechanism, and milling down the air horn is on the list for this winter.
Car can be a little reluctant to start, but nothing a few pumps of the throttle doesn't cure.
Funnily enough, it always starts real easy when its very very cold, it's autumn, like now, when I struggle to keep the balance between it not firing up or flooding it initially.
Once running, it ticks over just fine from cold.
Now If I can get away with no choke in the UK, sure you can as well.
Wilf
Old 10-21-2002, 11:48 AM
Cobra Make, Engine: Everett-Morrison, 347 Tri-power Stroker
Oh come on...
You have to run a choke just to gas-out all the critters moving into your garage when the weather gets colder.
Old 10-21-2002, 01:09 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
Thumbs up We don't need no stinkin' chokes
Take the choke parts off and deposit them in the nearest recycling receptacle.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
