SUPPORT OUR SPONSOR
Old 10-27-2002, 09:49 PM
Club Cobra Member
Send a message via ICQ to BigJohn Send a message via AIM to BigJohn
Question Tremec Gear Ratios
I bought a Cobra with a 3:70 rear end and Tremec 5 spd.. How can I tell what gear ratios are in the box? Are there ID numbers on the case? If no ratios were specified when the box was purchased, what gears will it come with?
Thanks,
BigJohn
Old 10-28-2002, 02:57 AM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
3.27, 1.98, 1.34, 1.00, .68. These numbers are for the 3550 and the TKO. The TKO II uses a .83 overdrive. Not very common. Jack the rear end up, mark the drive shaft, put the car in 5th. gear, and rotate the engine by hand (with a breaker bar) 2 full revolutions. Have somebody underneath the car to count the number of revolutions the drive shaft makes. If it is slightly under 3 revolutions, you have a 3550 or TKO. If it rotates slightly under 2.5 revolutions, you have a TKO II, which has only been around for about 1 year, more expensive, thus making it kind of rare.
While you are at it, put the car in 4th gear, mark the tire, and see how many revolutions of the engine it takes to rotate the tire one time. This will tell you what your rear end gear is.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 10-28-2002, 07:57 PM
Club Cobra Member
Jeff,
This is excellent and invaluable information. The solution to determining the ratios was just too straightforward and simple.
Thanks a 3.27 million!
BigJohn
Big John building a beautiful blue bullet in Benicia
Old 10-28-2002, 09:31 PM
Jeff Frigo's Avatar
BigJohn:
Any time. Welcome to CC.
Jeff
Mark Donahue
Old 10-28-2002, 10:59 PM
Default World Class T-5 OD ratio?
How about the OD ratio for the World Class T-5? I hear everyting from .68 to .76. Anyone know for sure?
TIA, Mike
Old 10-29-2002, 01:22 AM
mikiec's Avatar
Try here:
http://www.geocities.com/MotorCity/D...66/t5data.html
http://79indypace.stangnet.com/swap.htm#table
Hope this helps..
Mike
Old 10-29-2002, 03:25 AM
Try this for the gear ratios.
http://www.ttcautomotive.com/products/TR-3550.asp
Jack Z.
HTML code is On
