Old 11-04-2002, 12:49 PM
Cobra Make, Engine: Lonestar 427 SC w/351 with 400 HP: 69 Black Jade GT500
Question Timing Mark Bracket for 351W
Does anyone know where I can obtain a bracket that will extend out past the cooling hoses so I can see the timing mark. The engine is a built 351W.
I can see the pulley marks fine, it is the top mark that is covered by the water cooling hoses. The water pump looks like a Japanese brand and that may be why this happened.
Or any other solutions? I tried to extend the paint out to the end of the bolt where I thought it should be. But, this does not seem very exact.
shelbyman
Old 11-05-2002, 09:49 AM
Default timing pointer
www.reichardracing.com
supply timing pointer (passenger side)
Bernie
Bernie 289 FIA
Old 11-05-2002, 10:41 AM
Mr.Fixit's Avatar
You can make one out of sheet aluminum in about 15 minutes.
Old 11-06-2002, 02:32 PM
To Peruch: thanks, they have cool stuff. Will this one actually fit though. It seems like the cooling hose is in the way. Mark
shelbyman
Old 11-06-2002, 08:48 PM
What year is your motor? Prior to 1969 1/2 the timing marks were on the drivers side. The water pump dumps out on the passenger side. After 69 1/2 the marks were changed to the passenger side. The water pump dumps out on the drivers side. I've also been looking for a timing pointer for my pre 69 1/2 351W. But I have also determined that i will have to make my own.
