SUPPORT OUR SPONSOR
Old 11-15-2002, 07:48 AM
Cobra Make, Engine: SPF - 427 Stroker
Default Leaking
I had my rear main seal replaced about 3 months ago, it was leaking allot and making a mess of my garage floor. 2 piece rear main. After the fix it has been dry as a bone but has just started dripping again. Nothing major at all, maybe 3 or 4 drops on the floor making a small (quarter sized) puddle.
Is this normal ??? Was just wondering if any of you also have a 351W that leaks. It is coming off the bottom of the bellhousing. Thanks in advance.
NEVER LIFT
Old 11-15-2002, 08:07 AM
ROSS WEAVER's Avatar
Agro1,
I don't know about 351's main seal leaks, but my 460 does and I've been told thats normal for a 460. I don't think any leak should be considered normal. I'm curious to see if someone has a remedy as I'm sure you are.
Ross
Old 11-15-2002, 09:18 AM
jams's Avatar
Cobra Make, Engine: B & B
I had a 460 in an old Pickup. Replaced the rear seal and it started leaking again. I agree no leak sould be considered normal.
Just enough knowledge to build a cobra and be dangerous...
You can observe a lot from just watching.
Old 11-15-2002, 09:23 AM
Mr.Fixit's Avatar
Only a few drops, that's better than normal. Ever watch drag racing, what do you think the guy with the rag is wiping off the ground while the funny car is backing up after his burnout? Consider it free rustproofing.
Did they cut the block and put in a one-piece seal, or just replace the 2-piece unit?
Quit worrying, you have what, a 550 Hp motor, in a car that everybody gives you the thumbs-up while driving, that is a chick magnet, and you are upset about a tiny oil spot on the garage floor. It is 40 year old technology, they leaked then, and still do now.
Old 11-15-2002, 09:36 AM
Fixit - it's a 2 piece - Please, do you think Coast would spend the time cutting the block to use a 1 piece - those guys didn't inspect the crank before putting it in, hence the first main seal failure...I hear ya though - Not worried about it at all, I assumed a small sepage is totally normal, but was just wondering if it is going to get worse requiring another replacement...Not that it really matters in bigger picture - the car is bad A$$, the motor finally seems to be sorted out and I couldn't be happier.
NEVER LIFT
Old 11-15-2002, 10:06 AM
bonyhadi's Avatar
Cobra Make, Engine: ERA535 with 427FE s.o.& toploader
Send a message via AIM to bonyhadi Send a message via Yahoo to bonyhadi
Isn't that your car for sale on Cobra Country?
Need more horsepower, raki and where in the hell did The REDHEAD go off to?
Old 11-15-2002, 10:38 AM
Bony - Yea...Is it still listed ?? Got a few bites, not really interested in selling it though...Just wanted to see what it would fetch and would have sold it for the asking price maybe a couple G's less...The 12:5.1 compression running on 100 octane was an issue for those that were interested...Why do you ask ?
NEVER LIFT
Old 11-15-2002, 04:31 PM
Tony Radford's Avatar
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Agro1,
My Windsor has had a leak since I bought it. It recently got worse, so I had the seal replaced last week. Mine has a one-piece seal that you get to by pulling the flywheel. In the process, the mechanic detected a potential leak in the oil pan gasket, so he replaced that too. Now the leak is even worse. I drove it down to Southern Automotive to redo everything. I'm running Mobil 1 5W30 synthetic oil. It will be replaced with 10W50.
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
Old 11-15-2002, 07:29 PM
Rick Parker's Avatar
Lightbulb Oil Leaking
Could be that oil is seeping past the threads for the flywheel or flexplate bolts, use sealer on the threads. Otherwise a small thread of silicone from the edge of the seal (with the main cap off) to the outer edge of the cap mating surface may prevent the seepage you are experiencing. It's not necessary to tolerate an oil leak.
Rick
Old 11-16-2002, 04:31 AM
coosawjack's Avatar
Cobra Make, Engine: Classic Roadsters '66 427 Replica-SOLD
Hey Guys....
I've posted this before but for those who didn't see it, get a "Ready Sleeve" kit for your 351W two piece rear seal block. The FelPro part number is 99376 and I think you can install it with the engine in the car. The sleeve effectively increases the rear seal journal about .009".
I had the "Leak From HELL" from the rear of my 408W and replaced seals so many times I can't even count......I even talked to a guy in Mooresville, NC who will machine the block for a one piece seal. After installing the sleeve kit....NO LEAKS...NADA!!!! I even put a little oil on the block plate every oil change to keep down the rust...Ha Ha!!
I'm sure they make these kits for all Ford engines, but I don't have a part number for 460's. Call 800-325-8886 and the FelPro people will surely help you.
Give it a try...The whole kit with install tool is less than $50.00 and it works!!!
Jack
Old 11-16-2002, 04:38 AM
RACER X #99's Avatar
It's a Ford it is supposed to leak.
Old 05-07-2003, 12:57 PM
Send a message via Yahoo to DJMHEMET
jack, i ordered the felpro kit#99376 and got a sleeve for a harmonic balaner? and even then its the wrong diameter for a 351w balancer. so im a little lost on how it would repair the 2piece rear main leak on my 408 stroker? any info would be appreciated,dave
Old 05-09-2003, 09:39 PM
Club Cobra Member
Send a message via AIM to Tinker51
Talking Quarter sized oil leaks are for kids
You all have clearly never been around radial aircarft engines. When they stop leaking oil you get worried.
We have enough youth. What we need is a fountain of common sense
HTML code is On
