SUPPORT OUR SPONSOR
February 2026
Old 04-07-2003, 09:03 AM
Blake Olson's Avatar
Location: Right in the middle of the beautiful Texas Hill Country - Boerne, Texas,
Send a message via Yahoo to Blake Olson
Default Spinner safety wire- help!
Does anyone have photos and or a diagram, directions, etc, to property safety-wire your spinners to the wheels?!
thanks!
blake
"They're lining up on both sides of the ocean..
and nobody's willing to compromise
in the search for the smoking gun..."
"Charlie Don't Surf!"
Old 04-07-2003, 09:22 AM
Hi
I believe bob Putnam at ERA has a pic or instructions of the procedure
There has been discussion on the topic in that the "top to the back" rule for tightening is best remembered. That means the topmost ear on a spinner is driven towards the back of the car to tighten the wheel on.
Now for wiring, one ear is drilled and then wired to the spoke of the wheel in such a manner as to leave a small amount to slack allowing the wire to not look TAUGHT. Wired also in the same top to the back configuration.
The reasoning behind this is that the wire served more as an indicator of the knockoff loosening and backing off, if the safety wire ever suddenly became TAUGHT.
People here also discussed the different techniques and preferences of the front side or inside of the wheel route etc.
You may firn the thread in a search....have you looked??
Good old Bob P at ERA......
http://www.erareplicas.com/427man/wh...htm#safetywire
There are more threads.....
safety wiring knock offs
Tim
Old 04-07-2003, 10:00 AM
Found it on ERA's site! Thanks Bob!!
Old 04-07-2003, 10:13 AM
terry lee's Avatar
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
FINISH LINE HAS A TOOL FOR MAKING THE HAYWIRE TWIST REAL EASY FOR ABOUT $35. EVERYONE WITH SPINNERS NEEDS ONE FOR THEIR TOOLBOX.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
Old 04-07-2003, 10:15 AM
got one at Northern Tool!! Works great!!!!
blake
HTML code is On
