SUPPORT OUR SPONSOR
January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 04-26-2003, 10:31 PM
Default 351C Sparkplug Help!
I did the initial startup of my 70 351C. Fired and ran great within a few seconds of the turn of the key. Then things went down hill. I noticed leaking around the spark plugs. Upon inspection the heads have a flat land at the plug thread and the plugs installed are beveled without a compression seal. Obviously not compatible. Unfortunately 4 parts stores all call out the plug which is obviously wrong... Any help or numbers for the right plugs?
Old 04-29-2003, 01:33 PM
351C heads use a small (5/8 hex) tapered seat spark plug. Autolite 25
Old 04-29-2003, 02:57 PM
Cobra Make, Engine: CMC Cobra ,351-Cleveland, 375 hp
you can use NKG ur4 stock # 6630 gap at .035
I have no problems with these plugs.
Rich
Old 04-29-2003, 04:42 PM
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Straight from Southern engines:
my 4V uses:
motorcraft: ASF-42C
autolite: 15 or 14
champion: V-12YC
accel: 276
gn
HTML code is On
