Old 04-26-2003, 09:31 PM
Default 351C Sparkplug Help!
I did the initial startup of my 70 351C. Fired and ran great within a few seconds of the turn of the key. Then things went down hill. I noticed leaking around the spark plugs. Upon inspection the heads have a flat land at the plug thread and the plugs installed are beveled without a compression seal. Obviously not compatible. Unfortunately 4 parts stores all call out the plug which is obviously wrong... Any help or numbers for the right plugs?
Old 04-29-2003, 12:33 PM
351C heads use a small (5/8 hex) tapered seat spark plug. Autolite 25
Old 04-29-2003, 01:57 PM
Cobra Make, Engine: CMC Cobra ,351-Cleveland, 375 hp
you can use NKG ur4 stock # 6630 gap at .035
I have no problems with these plugs.
Rich
Old 04-29-2003, 03:42 PM
Straight from Southern engines:
my 4V uses:
motorcraft: ASF-42C
autolite: 15 or 14
champion: V-12YC
accel: 276
gn
