SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-27-2003, 07:16 PM
petek's Avatar
Cobra Make, Engine: CRL, 351W, Tremec TKO
Default Wheel Weights
Gee, do ya think this could have been part of the problem of high speed vibration??? Thank goodness wheel weights are lead and that lead is soft!
I've since had tape weights installed onto all four wheels. No more high speed vibration!
Pete K.
Who is John Galt?
Old 04-27-2003, 08:15 PM
Dwight's Avatar
Default LEAD
BULLETS ARE MADE OF LEAD. AND THEY ARE SOFT BUT IF GOING FAST ENOUGHT, THEY MAKE HOLE IN THINGS!
IS THAT A PIECE OF THE RIM MISSING?
Old 04-27-2003, 08:30 PM
G.R.'s Avatar
Cobra Make, Engine: NAF 289 FIA, 347 stroker with Weber 48's, building a '48 Anglia gasser, driving a '55 Chevy resto-rod
Send a message via Yahoo to G.R.
Sure looks like it--Wow!
"Breathe in... Breathe out... then move on with life. Lifes too short to sweat the small stuff"
Old 04-27-2003, 08:54 PM
petek's Avatar
No, the wheel is fine (thank goodness)! The only thing that got ground down was the wheel weight. I looked and didn't see any damage on the A-arms.
Thinking back I do remember a squeeking noise when I had the steering all the way over in a left-hand lock. Was months and months ago.
The other front tire's wheel weight and both rear tires wheel weights were fine.
Pete K.
Who is John Galt?
Old 04-27-2003, 09:27 PM
Dwight's Avatar
Default LOCK TO LOCK
IF YOUR WHEEL IS TOUCHING THE UPPER CONTROL, YOU NEED TO INSTALL STOPS IN THE STEERING RACK. PULL THE BOOTS BACK AND INSTALL A CLIP AROUND THE ROD. YOU CAN MAKE THE CLIP OUT OF 1" PVC.
HTML code is On
