SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 04-30-2003, 02:49 PM
Question Contemporary Front End Alignment
My Car has coil over penske adjustables. I took it to an alignment shop. They set the caster & Toe, but couldn't figure out how to set camber. Neither can I ..... HELP... Do we shim the upper arms ? THe car has too much negative camber and wears tires quick.
I understand a bit of negative is good for handling , but this is too much...
Old 04-30-2003, 05:05 PM
Denny,
You may be able to get some help from Don Borders at Image Motor Works--he used to build Contemporary cars and is now making a very similar car with Boyd Coddington. I think you can get the phone no., etc., just by putting the company's name into a search engine. I do believe it's shims--that's what I have to do with the torsion bar front end, anyway. But Don's an expert.
TT
Old 04-30-2003, 08:22 PM
KobraKarl's Avatar
Denny,
Just did this myself ,had a lot of neg camber and I thought it was week torsion bars ,and was going to adjust them . before I did I took it to a local old Jaguar specialty shop , they were very interested in the build and very familiar with the suspendion. The owner immediatly pointed out that I had a lot of toe out ( more than a half inch) I asked about the torsion bar adjustment I was considering , and he pointed out that would only lift the front of my car two or three inches ,and the camber was set only with shims.
good luck ,Karl
Foolish consistancy is the hobgoblin of tiny minds
Old 04-30-2003, 11:31 PM
Dominik's Avatar
karl,
do you know what it would take to trasform the torsion bar suspension into a coil over?
just putting coil overs in? the coil over probably does not fit through the upper wishbone.
dominik, cape town
If I don't respond anymore, that's because I can't log in
Old 05-01-2003, 10:22 PM
KobraKarl's Avatar
Dominik,
Don borders at Image Auto Works in southern california makes a conversion kit with all parts neccesary including a weld in "x" brace and tubular "a" arms that are bolt up .. I have considered it ,but since im not not a real serious track guy, I am focusing my funds on other parts of the car.
KK
Old 05-01-2003, 10:49 PM
Dominik's Avatar
thanks karl,
I have the x-brace already, so it would be thewishbones to change.
dom, cape town
Old 05-05-2003, 09:22 AM
Talking Front End Done
In case anyone else wants to know. After a call to Don Borders at Image. We
unbolted the upper control arms and put in 1/8 shims behind them. Took my over 1 inch lean in back to less than a half inch.
We made shims with holes instead of slots so they can't fall out. I understand you can use Jaguar alignment shims also.
My car still has negative camber, but nothing as severe as it was.
HTML code is On
