SUPPORT OUR SPONSOR
Old 05-02-2003, 08:41 AM
Cobra Make, Engine: ERA 575 with Shelby Aluminum 427 Stroked to 468
Default Clear Coating for Bare Steel
I am curious if anyone knows a clear coating that has rust inhibitors in the coating. I was considering applying a clear coating to a finished but bare metal roll bar. I looked at POR 15's website and their product PELUCID claimed to be suitable for painting over "unpainted steel" which I thought was bare steel, but the rep on the phone said it's not going to prevent the rust. Looks like I will go with a high gloss black finish instead. Any suggestions would be appreciated.
Old 05-02-2003, 09:28 AM
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Chrome it or powder coat it.... about the only choice other than plain old spray paint.
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
Old 05-02-2003, 10:07 AM
Mr.Fixit's Avatar
I have always been fond of semi-flat black paint, or powdercoat. But to each his own. You may want to check Eastwood, they sell polishing stuff, and have a clearcoat for polished metal, never tried it myself though.
Old 05-02-2003, 10:34 AM
Cobra Make, Engine: Power Performance Body, Contemporary chassis, 427 CO, Big I/O toploader, AMP Billet rear, Trigo 6 pin
I just ran into the same problem. Rustoleum makes a clear coat spray. I bead blasted and cleaned and painted. Two weeks later, it is rusting under the clear coat. After a little investigating, I need to phosphate wash the parts first. This will thoroughly kill all non visible rust and provides a light phosphate coating to prevent rust. Clear coat right over the top. I was recommended the PPG DX579 metal conditioner. I think this is a typical process for body panels.
Dave
Old 05-02-2003, 12:41 PM
thanks Dave,
it's funny how you can ask for something a certain way, and get a totally different answer. I called a local autobody supply house and asked if they had any kind of clear product that inhibits rust, they said no. I called back later, asked if they had dx579, and then I asked if I use dx579 to treat bare steel, can I then go and clear it and prevent rust, "yah that'll work"
I think it's worth a shot, it looks so beautifully raw after the bare steel has a finished surface.
HTML code is On
