SUPPORT OUR SPONSOR
Old 05-17-2003, 05:15 AM
TonyMadrid's Avatar
Cobra Make, Engine: A&C 351W, C4
Question Speed Demon Carbs
Hey Guys,
I need some info on carbs. I'm building a 351W and I am thinking about going with a Speed Demon 650. What is the difference between using vacuum or mechanical secondaries. What are the pros & cons of each?
Thanks,
Tony
Old 05-17-2003, 05:40 AM
Roscoe's Avatar
Tony,
All I know is that many people have had problems with Demon Vacuum carbs. I have a 650 mechanical and love it. Never had a problem.
Roscoe
Roscoe
Old 05-17-2003, 05:59 AM
TAB TAB is offline
I run a 750 SD with mechanical secondaries, had some problems with the venturies and had some work done to them to open them up a little but overall even before the work was done ran pretty good.
Todd
Todd Baumann
FFR 2086
Go Red Wings!!
Old 05-17-2003, 06:56 AM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Similar setup. 351W, TFS heads, Comp hydraulic roller cam. Replaced Holley with Speed Demon 650 DP and it runs great. Demons worth extra $$ over Holley.
Rule of thumb for vacuum secondaries vs mechanical: Heavy car, small engine, auto trans, tall rear gears (under 3.00), use vacuum. Light car, large engine, manual trans, short rear gears (over 3.00) use mechanical secondaries.
The only Cobra I could imagine using a vacuum secondary carb would be a 302, auto trans, 2.88 rear gears.
Old 05-17-2003, 01:01 PM
viking's Avatar
Cobra Make, Engine: SVM7688, 427 FE med riser, doug nash 5-speed, 3.54 9 inch locker.
I run a 750 SD w/vacumn secondaries on my 427 FE , I have gone from 850 holley mechanical to 750 SD mechanical to 750 SD vacumn, Berry Grant finished what holley started, the vacumn carb has no problems at all, it starts fine, a little to much foot still lites the tires , hard 1st to second shifts still raises the left tire off the ground a bit , you still DON'T nail it in the turns, and while crusing I'm getting 4 more mpg, in short other than the mpg I don't notice any difference. Don
Objects in the mirror are losing
Old 05-17-2003, 04:46 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
Talking Me too!
750 Race demon, mech secondaries, no problems.
I wait for the water temp to come up a little before I drive the car anyway. As a matter of fact, I don't rev past 3000 till I get some oil temp.
Eric
HTML code is On
