Old 05-23-2003, 03:43 PM
wicked fast's Avatar
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Question ??? Lucas relay part numbers ???
Who has the 33XXX Lucas part numbers for the:
horn relay ?
fan relay ?
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
Old 05-23-2003, 07:04 PM
ttt
Old 05-24-2003, 07:26 AM
Cobra Make, Engine: NAF 427
OK. Here goes ,after many weeks of intense research, the following is more info than you may want:
The original horn/fan relays were Lucas p/n 33188E but are long since obsolete. These were 3 prong relays (C1,C2,W1) and were internally grounded. The current equivalent is Lucas p/n SRB113 (33316E) which is a 4 prong (C1,C2,W1,W2) and costs about $60. An alternative is the Lucas p/n SRB111 (33302B) which is a 5 prong (2@C1,C2,W1,W2) and costs about $30. (Go figure). Cut off one of the prongs at C1 and voila , you have a SRB113.
The signal flasher is Lucas p/n SFB100 (35010) which is a screw on terminal version which matches the original equip.
The main fuse block is a Lucas model SF4 , p/n 54038067 and is a 4 fuse block with a center screw bakalite cover that most original cars have broken/discarded.
There are some cars with an auxillary fuse box , Lucas model SF5 , p/n ? , which is a 2 fuse box .
And last and most infamous , the Signal/Brake relay (the large 8 screw on connector relay), which is a Lucas DB10 and is still available.
Best source for all these parts : www.vintagemotorspares.com
A British dealer and much cheaper than any US source.
The regulator is a Ford C6AF-10200D (original) or C5AF-10316A (alternate) and both are black with silver lettering Autolitr decal).
The starter solenoid is a Ford B6A-11450-SPP (before 3/65) or -BLK (after 3/65).
The corrrect alternator would be a Ford C5TF 10300-F.
Best source for these parts is : www.amkproducts.com
Hope this helps.
Greg
Old 04-01-2014, 09:20 AM
ALF's Avatar
ALF ALF is offline
How would the interesting list from Greg look for the CSX2xxx (289 Cobras)????
Old 04-01-2014, 12:01 PM
I'm certainly no expert. Many others on this forum with a wealth of knowledge. My baseline reference has been the following:
Old 04-01-2014, 12:06 PM
Having trouble loading the last page. Have I reached some sort of limit?
Greg
Old 04-01-2014, 10:32 PM
ALF's Avatar
ALF ALF is offline
Hi Greg
Many thanks
you uploaded 5 pages - is this correct or should there be a 6th page?
Based on this information LUCAS is the way to go.
Old 04-02-2014, 07:21 AM
Hi Alf. I posted a seperate thread with page 6. For some reason pic wouldn't attach to the Reply.
Greg
Old 08-26-2016, 02:28 PM
Registered User
If you need the lucas 3 terminal relay try HR 101 at NAPA
