Old 07-24-2003, 08:13 AM
Default Tko 2 Noisy
BOY THIS TRANY SURE DOES WINE ALOT IS THIS NORMAL(TKO 2).
ANYONE
Old 07-24-2003, 08:18 AM
Cobra Make, Engine: Dax Tojeiro, 450bhp 383 ci Stroker, Tremec TKO and Contemporary CCX, Big Block Ford, old school.
I run a TKO and I can't say I've any complaints about it being noisy, maybe I just can't hear it over the side pipes.
Kev Davies, Wales (UK)
CCX-3-4028.
445 ci Ford FE
Old 07-24-2003, 08:51 AM
wilf leek's Avatar
I also run a TKO (not a TKO2 - should be no difference in noise) and have underslung exhausts. I can "just" hear the gearbox in 2nd and 3rd at lower speeds, that's all.
Much more noise from the jag rear end, which is normal.
Wilf
Old 07-24-2003, 08:55 AM
KobraKarl's Avatar
Wilf,
I have been a little worried about the mild howl coming from my jag rearend ( hold the jokes for a second) you saying this is to be expected?
KK
Old 07-24-2003, 09:21 AM
I remember someone saying that the TKO has straight-cut gears. I find this hard to believe, but if true, this would account for the whine. All straight-cut gears are noisy and it is nothing to be alarmed about.
Can someone confirm straight cut gears in TKO?
Old 07-24-2003, 10:21 AM
The tko does not have straight cut gears. It should not make any whine noise. Could be a bearing issue internally. Scott
Old 07-24-2003, 10:27 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Lightbulb Call Dave
You might want to call Dave Kee.
He maigh be able to tell you what's going on.
If someone else suggested this, sorry for the double suggestion.
Trularin
Old 07-24-2003, 12:34 PM
Does the noise come and go with gear selection?
If it remains constant, I would suspect rear end.
My TKO makes no noise I can hear over exhaust and engine sounds.
gn
