SUPPORT OUR SPONSOR
Old 08-04-2003, 10:06 AM
Send a message via MSN to CowtownCobra
Default Electric fuel pump placement
I have a Holley blue electric fuel pump. It is mounts about mid level with the tank. The fuel pickup hose runs out of the top of the tank and then down to the pump. Will this work? Seems to me it will not pick up the fuel in the bottom of the tank.
Old 08-04-2003, 10:11 AM
Curt C.'s Avatar
Cobra Make, Engine: Classic Roadster; 351W
Mine is set up in about the same position and it works fine.
Old 08-04-2003, 10:17 AM
Mr.Fixit's Avatar
If you can, keep the head of the pump as low as the lowest fuel level in your tank, then it will always be primed.
HTML code is On
