SUPPORT OUR SPONSOR
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-29-2003, 09:21 AM
Default Ammeter & Alternator wiring questions
I have a Contemporary with a Ford 351W that the ammeter has never worked on. In their instructions they said to bridge the A & S terminals on the voltage regulator. Would that prevent the gauge and warning light from working? I do have the alternator stator connected to the S terminal on the regulator. There are no other charging issues; the car cranks well and starts whenever I get in to it.
TIA
Tom
Old 08-29-2003, 10:46 AM
Clois Harlan's Avatar
Tom,
I had a similar problem about 4 years ago when I built my Cobra. After becomming completely frustrated I took my alternator back to AutoZone and traded it for one with a built in regulator (I think it cost about $50 for a 70 amp). Now everything works great.
Good luck,
Clois
"Let's roll"
"Be part of Something Good
Old 08-29-2003, 11:12 AM
The warning light will only work with the layout on the right. If the basic wiring layout is OK, the ammeter should work with either regulator setup.
If you disconnect the wires at the ammeter, everything should be dead.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 08-29-2003, 06:13 PM
Thanks for the info Bob. Is there any way to test the ammeter at home?
TIA
Tom
Old 08-30-2003, 05:32 AM
Tom,
If you're not getting any reaction when you turn the headlights on (or better still, the fan), either the ammeter is defective or it's wired incorrectly.
Bob Putnam
-E.R.A.-
Old 08-30-2003, 06:43 AM
PatBuckley's Avatar
A simple test I have been told about is to put a screwdriver to the back center of the alternator - if it is magnetic the alternator is working.
I have yet to run into a bad alternator so I have never been able to "prove" this.
Old 08-31-2003, 09:04 PM
Cobra Make, Engine: Unique FIA
Thumbs up
Pat,
Damn, I never thought of that. Makes perfect sense as an energized field winding is a big magnet.
I'm gonna go out and try it.
Steve
All my ex's live in Texas
Old 09-04-2003, 08:04 PM
Bob,
You've been so helpful about this. Can I ask you for more troubleshooting advice? I have the warning light wired as you described but it still doesn't light up when I turn the key. I can get it to light up if I connect my test light to the I terminal on the voltage regulator plug and ground it. I also have 12v at the A terminal. So it seems like I'm missing a ground connection somewhere. There are 2 terminals on the back of my alternator that have no markings. Do these need to be grounded?
Thanks
Tom
Old 09-05-2003, 05:02 AM
Snakebyt,
The alternator needs to be grounded some way, but this is usually done automatically if it's mounted to the engine without insulators. I use a "redundant" ground wire to an alternator stud just in case other grounds have corrosion.
Make sure that the voltage regulator is grounded too.
Bob Putnam
-E.R.A.-
Old 09-25-2003, 06:16 PM
The problem turned out to be the voltage regulator. $9.95 (+ $8 Shipping and Handling!) to JC Whitney fixed it all. The light lights, the needle moves, it's a beautiful thing. Thanks to everyone who answered.
Tom
HTML code is On
